Hi Fellas,
I have the bench setup for the alarm on the house sussed now (I think) thanks to some really top help from the forum. I originally intended to get the house sorted and then copy the setup with the same panel for the garage and workshops.
Then I thought perhaps it could be done all from the same panel, this would give the big advantage of being able to set the garage from the house keypad(s). I have plenty of cables in place in a duct between the buildings
My System so far is a Texecom 48 Elite, XP8, 2 RKP, 12 Zones over 1 Areas; House (Area A)
I want to expand it to 4 RKP over 16 zones in 2 Areas (12 in A, 4 in B) for to include Garage/Workshops (Area B).
Both House and Garage to have 2 RKP each
Physical Bells are mounted on both House and Garage.
Bell on A is on Bell outputs from Panel with 60 second Delay.
OP1 in Panel is Internal Sounder for A set as “Alarm”.
Propose to use OP2 Panel for Internal Sounder for B set as “Alarm”
Propose to use OP1 in XP8 for Bell on B set as “Bell SAB”
Propose to use OP2 in XP8 for Blaster 127 (at the top of the House gable)
Will be possible to dis-arm/arm area B only from RKP in Area A ?
If both areas are armed and then Area A or B is entered by a user would the entry code disarm both areas or just the one that is entered?
Can it be programmed so that only the Internal sounder and (delayed) Bell go off only for their own area. i.e house bell (Area A) will not ring if Garage (B) is triggered.
Can the blaster be made to go off when either Bell goes?
Sorry for so many questions but at this point I’d just like to know if it looks feasible/practical/possible. I’m sure I’ll run into individual problems along the way which hopefully I’ll trouble shoot with the help from the forum, failing that I guess I’ll revert to 2 Panels.
Thanks for any help or advice you may offer.
