Shallow recessed LED downlight
4 Jan 2006
Worcestershire
Can anyone recommend a good quality LED downlight, but needs to fit in a recess of around 90mm.
Haler H2 Lites any good? Would prefer something cheaper.
These
http://www.scolmore.com/documents/inceptor.pdf[/QUOTE]
They look interesting. Around £25 each - not bad?
Have you used them?
They look easy to put in as well. I presume I could need to get something like this http://www.websparky.co.uk/acatalog...CLCT300.html?gclid=CPie-MnDhbsCFW_JtAod02gAwQ and then a couple of these http://www.lumalighting.co.uk/Wirin...+cable).html?gclid=COa-kujDhbsCFQrJtAodcX8Asw
Then it would be mains into the CT300 and then the prewired cables to the lights?
I have used them on a couple of jobs, once where limited for space and the other they were supplied by client.
You can use the hub, but you require access to it or you could configure by daisy chaining, I think I used the male CT101C?
