We have a shaver point in the bathroom that has been used to charge toothbrushes for the past 15 years or so. The shaver point itself is powered by the light switch so is only in continuous use when the light is switched on.
A few weeks ago I noticed that the toothbrush was no longer charging so I followed these steps
1) Having had a toothbrush with a dead battery before I changed the "unreplaceable" battery but no joy
2) Suspecting that something else on the toothbrush was faulty we ordered a complete replacement toothbrush with new charger and found that the new toothbrush also did not charge.
4) I bought a two to three pin adapter and confirmed both tooth brushes would charge from a three point socket
3) Now suspecting the shaver socket I ordered and fitted a replacement but still no joy.
4) Using a meter I can see 240V on the input side the old and then the new shaver socket whilst also testing that both toothbrushes are failing to charge off either.
Could it be that both shaver sockets (old and new- both Nexus) are faulty? Before I buy a third socket I want to rule out anything else that could be causing the issue or anything else I could test. Any advice would be appreciated.
