Shed Base
10 Oct 2014
Liverpool
Hi all,
Building a new shed
I’ve got the slabs laid, and I’ve bought some plastic base to raise it off the ground which I’ll screw to the slabs.
I’m going to insulate the floor underneath with PIR boards, my question is do I need any membrane under the shed ? And can I cap off the open end of the floor so you don’t see the insulation?
Mark
I used adjustable feet. The round ones... I made a frame with the adjustable feet and placed shed on that.
Why insulate floor?
If you use kimgspan moisture can't get through it.
I have a gap under to allow airflow as it's going to get ground damp.
Would it not be easier to put some 25mm kimgspan on the floor with wood sheets over... Maybe
Why insulate floor?
I’m building the shed from scratch so wanted to insulate the shed base underneath whilst I have the chance.
Only reason i can see for insulation is if you'll be working through winter in there - condensation will be a problem if you seal the gaps too tight.
Hi all.. On just thinking the plastic base will just be for air flow, as I already have a flat paved area.. will they need filling with gravel ?
You don't need to screw the plastic base to the slabs, the weight of the shed will hold it.
Airflow underneath is essential to prevent rot, don't fill the underside completely, leave and airspace of at least 50mm between bottom of floor joists and the insulation, no gravel.
PIR seems overkill for a shed, xps (polystyrene) would be cheaper, or just use foam mats inside the shed.
I like Wayners idea, put the insulation boards down directly on the joists and floor straight on top, screwed through.
