Shed insulation
21 Jul 2019
Hello all.
Just after some advice. I am looking to insulate my shed for all year round use. I have looked on various forums and now more confused than ever.
The shed was a bespoke prefab made into a number of panels with 70mm deep stud frame, a breather membrane and then 20mm outer cladding. The breather membrane is almost tight against the inside of the cladding. (I thought normally there should be a gap, but it is what it is)
I would like a little sound proofing and so decided to go with rw3 rockwool. 35mm. And yes I do know at that thickness it wont make a huge difference. However, I have read insulation should have an air gap between the cladding and the insulation.
The next issue I have is that rockwool is to some extent flexible and will sag slighty over time and I need to somehow keep it away from the cladding, so from outside to in - I was going to put spacers on the inside of cladding(with breather membrane) then push/ fit 15mm celotex board up to this(leaving an 20mm air gap) Then push the rockwool up to the celotex filling the rest of void. Then a vapour barrier and then soundbloc plasterboard.
As I'm sure most of you will say, I have no idea what I am doing and you would be right!
How can I make this work? Or at least make the best of a bad situation, as I have already bought the materials. How do I leave an air gap and stop the rockwool falling on the cladding at some otherwise?
Many thanks
I'm pretty much in the exact same situation you are. What did you end up going with?
Thanks!
Hi There. Go for a mutli foil like Superquilt and do 2 layers. Only need a 25mm air gap so with 70mm framing you can do the following. Inbetween frame going in at 25mm depth then a layer over. 25mm by 38mm batterns over that then the plaster board. Plus when taped the foil is the vapour barrier.
