shed supply
17 Nov 2012
Lanarkshire
Hi need advice I want a water supply to my shed I've already run a pipe plastic hep 20 think it was called to the shed, under the sink in the house is a valve connected to a washing machine hose that supply's outside tap what would i need to do to use this to supply both what connections would i need
Cheers skip11
Hi quick update after speaking to a guy at work he said all i need i a Y connection screw this to valve then screw outside supply hose to one side the connect a 15mm to 3/4 valve to shed supply pipe then screw a 3/4 to 3/4 flexie hose to join them up Is this possible would it do the job
Advice Welcome
Absolutely no idea. We need photos of the washing machine to outside tap 'valve', outside tap, hose you've installed and what you've installed at the other end.
I've never heard of hep20 being used outside (although I am just a DIY'er when it comes to plumbing). I do know it isn't UV stable so you can't expose it to sun if run above ground.
If you have buried it then I don't know any reason why you shouldn't have but I can't help thinking there must be a reason everyone normally uses MDPE.
I know my reply isn't answering the question you asked, so sorry if you have already considered this.
Good luck in the winter when it freezes up.
When the water has pumped out of the washing machine there is always a bit left in the pump which is usually enough to pop said pump when it freezes.
