Shelf For Lad's Lego
11 Jan 2004
Middle lad has bought himself a deep shelf to display his Lego models.
It is 25mm thick, 400mm deep and 1200mm long.
Would you think these brackets would be sufficient?
The Lego stuff is big and tall, but none of it is heavy.
Strong Shelf Bracket Mitre Reinforced Pattern 350 x 350mm White Pack of 2 EAI Brand : Amazon.co.uk: DIY & Tools https://share.google/HS3ZPaRX2auJesvzA
The only annoying thing is, there is no dimension for the depth of the bracket where the screw holes are, so I won't know what length of screw I'll need until they arrive I can measure them.
Thanks.
More than adequate, Lego doesn't weigh much, the depth of the screw holes varies I'd say from about 20mm at the corner to 10mm at the ends.
