Hi.Recently moved in to a flat and it has been full of surprises and I'll probably be a regular visitor to this site.
When stripping down the wallpaper in the Living room, I came across a hollow part of plasterboard.I pulled it away to expose a brick (outside) wall.The pointing of the brickwork crumbles quite easy.I have been told that as it is an old flat (approx 100 years old) it is limestone pointing and I should just repair the bad bits.What do I need to do before fixing plasterboard to the wall to cover the bricks?. I was told that I cannot fix plasterboard direct to the wall, but I cannot remember why or what to do. What is the best way of repairing the pointing?
DIY Novice!!
DIY Novice!!
