Short Dishwasher Inlet Hose or something similar
21 May 2011
Leeds
The supply pipe for our dishwasher is 30cm away from the the dishwasher. Currently having issues with the standard inlet hose kinking and causing water inlet errors.
I can't seem to find a short hose - can i use something else such as braided hose? Where can i get one with female on both ends. is it 3/8 BSP both ends I need? Can't seem to find one.
It'll be a standard 3/4" BSP female fitting either end I would assume. If you coil the hose and tie wrap it in the coil, it should sit at the back of the DW, kink free. If it still compresses then use a cold former.
