Should I consider an electric combi-boiler?
27 Oct 2009
Bristol
Hello,
I'm currently in the process of renovating a 3 bedroom semi and need to install a heating system. There is no gas to the property/ village and I am concerned about rising costs of LPG and Oil. I don't have the money to install an expensive "green" system, but was wondering if I should go with an electric combi-boiler from Thermaflow. Any thoughts or recommendations?
Thermaflow units are ok, a bit expensive, there are cheaper makes, with these types of units it is important to get the right electricity tariff, Economy 10 or Economy 20000, this ensures you can heat the unit cheaper, also ensure the unit is sized correctly for your property.
If you are worried out the price of oil or LPG, then you will have a heart attack when you get your first electricity bill....
Fit an oil boiler. some can be fitted outside. They have good oil combis as well. Insulate and draftproof as much as possible. You can insulate behind kitchen cupboards and units with foam. It all adds you and out of sight. The wall area these units take up is quite substantial in kitchens.
Thanks for all of that! The general consensus then would be that I'm better off looking at an oil boiler...
