OK, so I have a 1930's appartment, with a fairly old heating system. The pipes are all visible, run high up along the walls, and are about 2 inches in diameter (my plumber assures me these are huge pipes). I have old fashioned Victorian-esque radiators in each room - all installed in the correct places (under windows). It all works fine, although takes about 20 minutes to get all the radiators hot (apparently to do with the volume of water in the circuit?). I've just had a new Vaillant boiler and a Honeywell 7-day thermostat installed to control the system, which both seem to work very well.
I'd basically just like a few opinions from people as to what I should do with the current system. My plumber seems to feel that the pipework should all be replaced with modern pipework hidden in the walls. We're renovating the appartment, and aren't sure if we have the money to do such a big job. I'm not sure if the plumber just wants some work or not... When he emptied the system, he said the water ran very clear, which I understand means that there is no corrosion in the system. So, should I just leave it as it is? When it all fires up, the heating seems to work pretty well, and the radiators etc are all in keeping with other 1930s features in the flat (marble windowsills and fireplaces, oak floors, etc). What do people think?
