SHOULD I use FERNOX or Silicone Sealant ? theories please.
1 Nov 2004
gentlemen,
on your advice, I am planning to use either of the above, to seal up the OVERFLOW hole / seal, on my ACYLIC BATH.
Now, because the Acrylic is woven, like fibreglass, would SILICONE sealant be TOO STRONG a seal ?
IE, if i ever need to removed the silicion, will it start removing bit sof acrylic too ?
OR, would I be better off with FERNOX LS-X , which doesnt ever 'dry', and should be easier to remove ?
out of the 2, which would give the best, longer lasting, seal ?
cheers
BOOGS
i always use sanitary silicone for bath wastes and overflows, no problems yet...
any other comments, by any NON COWBOY type plumbers ?!!!
:lol:
BOOGSY
( Cheers Cowboy, think I might go with that.........)
The acrylic isn't woven. The acrylic is the smooth inside sheet and it's reinforced with fibreglass, not that it matters. I think LSX is a type of silicone rubber but I haven't used it for years as I found the shelf life a bit short and I was wasting most of it. I use clear silicone sealant from Wickes if I want to make sure.
I use sanitary silicon between washer and bath & between washer and overflow casting. Ditto for waste.
Jason
