Hi all,
As the title says really, I'm currently hacking a new build to bits so I can thread cat6 through the walls and have 2 cables left but they'll be going down the wall attached to the neighbours. To get around the first floor we've had to drill into the cavity either side of the floor and ceiling and thread them that way on the external side but we're not sure if there will be a cavity on the adjoining side.
Basically, do building regs state that there should be a cavity between two houses? If it makes any difference, in the loft on the external side it's thermalite blocks but on the internal side it's just normal breeze block.
Thanks in advance.
Thanks in advance.
