Should water shoot out of auto air valve?
23 Mar 2021
I've a combi boiler with an auto air valve, the cap is missing, it's been missing for years, when I press the valve down water shoots out, otherwise it doesnt leak at all, I'm assuming this is faulty, I'd appreciate any advice, I can change it if needed for about £20, it's not in the combustion chamber. Also if there is a problem and I manage to open it up and clean it and release it if seized, rather than buying a new one can I just replace the cap? Is it literally like a car tyre cap?
The valve automatically expels air, which is pushed out by the water,and closes before water spews out.
Show us a pic of it first
If water comes out of an aav, it's doing its job of expelling air that collects in it. Normally it's full of water and is a high point in the system that collects air, which it then releases. As the air comes out, water comes in to take the air's place, and the presence of the water shuts the valve again
If air comes out, it's not auto bleeding it
Cant say I've come across many auto air vents with a valve in it that you can push down (Shraeder?), that would defeat the purpose of it being an 'auto' air vent.
Most do have a dust cap that is loosened and any air is then expelled 'automatically' by the internal float dropping. When there is enough air in the top of the bottle the spring pushes the float down and releases the air, once the air is expelled the water fills back in and pushes the float back up and shuts the valve.
As suggested, sure it isn't the expansion vessel? A pic would help
Need pictures.
Not puppies, the neighbours wife or where you went on holiday last - the valve your referring to :)
