Hi guys, Just had a shower booster pump fitted, need to connect to power. Can I take a feed off the boiler circuit, fit an RCD fused spur, then connect the shower pump? Don't want to spur off upstairs ring, as that already has a RCD protecting it. Just need to know if this is acceptable, or wif it will be flagged as a failure on the next PIR.
Thanks lorry
Thanks lorry
