    Dismiss Notice
shower enclosure with back panel recommendations
Discussion in 'Plumbing and Central Heating' started by needmorstuff, 12 Oct 2014.
  1. needmorstuff
    needmorstuff
    22 Dec 2012
    188
    Thanks Received:
    4
    Yorkshire
    Country:
    Hi all,
    I am looking for recommendations for a 800x800-1100 shower enclosure. I want one that has back panels as I am sick of seals going and tiles getting manky etc.. I don't want one of those that look like they belong in a caravan.
    This looks entirely to cheap to be good but I don't have an issue buying from screwfix.. http://screwfixbathrooms.com/store/screwfixbathroom/800x800mm-pivot-door-shower-cabin-swecp8002
    Does anyone have any experience with kind of product they could share with me?
  2. Sponsored Links
    • Thanks Thanks x 1
  3. needmorstuff
    needmorstuff
    22 Dec 2012
    188
    Thanks Received:
    4
    Yorkshire
    Country:
  4. Have used the hydropanel on quite a few occasions (the vantage you mention is enclosures not panels) and like both the product and the finish. As always, follow the instructions to the letter especially preparation, joints adhesives and sealants.
    The reason for not using an all in one product is, for example, the one you have highlighted is glass all round. If you install tight to a wall then this means that you have still got to finish the walls to a high standard and you will never have access to the area after installation. You are left with an inaccessible space with the risks of mould etc.
    Using separate components means that you have some degree of adjustment - I've never met a building with walls meeting at exactly 90 degrees and plumb in all directions yet.
  5. jeff the gasman
    jeff the gasman
    8 Dec 2007
    13,683
    Thanks Received:
    5,016
    Cheshire
    Country:
    Don't use any panel made of MDF it fails.
    Make sure it's ply.
    Jeff
  6. Couldn't agree more - the product I linked to is ply cored with balancing laminate on the back
  7. DIYnot Local
    3 Sep 2019
    Country:
  8. Sponsored Links
Loading...
Share This Page
