I have a thermostatic shower in a downstairs wetroom.
The hot is fed from the hot tank via 15mm...and the cold is fed from the mains supply via a pressure reducing valve. also 15mm.
The hot tank is upstairs in the airing cupboard.
Flow at the shower head is good,but i would like better.
I have purchased a small capacity salamander pump and would like to boost this shower.
Can i tee into the present hot and cold supplies and fit the pump..?
Will the pump work satisfactirily with the present hot and cold supplies..?
thank you for your advice.
