- Joined
- 1 Feb 2005
- Messages
- 63
- Reaction score
- 0
- Country
I am about to fit a concealed thermostatic shower with a fixed head, and a seperate hose with a handset on the end.
My fixed head is on an arm, which is essentially a fancy pipe with a thread on each end 1/2" BSP. I assume that I use a 1/2" wallplate elbow behind the tiles to screw this into, but my wife is going to expect the shower head to point straight down, how can I be sure that the 1/2" joint will seal fully at the 6 o'clock position? Do I need to use a sealing compound on it, if so which one? I dont want to have it not really snug up when upside down and be loose at the correct position and unable to tighten another half turn. Just a shed load of ptfe tape?
The elbow for the hose to the "handset" part, looks like it can only be fitted from behind the wall by tightening a plastic "nut" against the back of the aquapanel, but this is an outside wall and I dont have that option. Are there wall elbows that can be fitted in this situation? All the websites I am looking at have no real information on this.
Lastly, the thermostatic shower I have bought has a big polished plate on the front to hide everything, what is the best way to secure this to the wall and seal the edge? Some sort of silicone?
Many thanks for reading and any help.
George
George
