shower pipe name
26 Apr 2003
hi, my electric shower is leaking from this pipe. I would like to know what it is so that i can find it in the shops or online. Would appreciate any help
The threaded end is less than an inch, but i'm after the general name as i'm not sure how the measurements are made.
thanks andy
It looks like a piece of the shower unit and not a standard plumbing fitting - so you may need to go to the manufacturer or a local stockist. Then again it may be the only the rubber seal (it looks like it has one on the pic) or perhaps it just needs a bit of ptfe tape and a good tighten (other end). Where exactly is it leaking from and what connects to it?
If in doubt always take old part to plumbers merchants to get an exact match.
Thanks Ant, i tried ptfe tape and eventually found it has a crack in it. I'll give the stockist a ring on Monday.
