I have two problems I would help resolving, I recently paid a plumber who didn't resolve my issues and if anything made it worse but perhaps pointed me in a better direction of my problems.
Problem1:
The water pressure in my bathroom is fine, the sink hot and cold water pressures are OK. However the pressure from the shower has been gradually getting worse. The plumber removed the tap (pictured) from the front and cleaned out some gunk from the filters. This seems to have resolved the hot water pressure, however the cold water is still a trickle. When leaving the tap removed and turning the hot and cold pipes on individually the hot flows well and the cold is a trickle from the wall.
He poked his screwdriver in and some orange gunk came out but this didn't resolve the problem. The pipes are not easily accessible due to being tiled in and under the bath is simply a metal sheet blocking access ( pictured ).
So is there any easy way to 'flush' the cold side out to remove any potential blockage, or is this simply going to be a big job of pulling off tiles ? Any advice to getting this resolved is appreciated!
Problem 2:
The same plumber replaced my tap which has been leaking slowly below, it turned out the leak was not coming from the tap but a joint near the top of the waste ( I have circled this in one of the pictures below ). What is the easiest way to resolve this, is it just a case of buying that plumbers tape unscrewing it placing on top and screwing back up?
Problem1:
Problem 2:
