Shower pump possible
19 Aug 2005
Cheshire
Cus originally had a venturi shower fed of mains pressure cold and hot from the cylinder , there is no way without major disruption of getting equal pressure feeds to the shower , so new normal valve fitted with a pressure equalising valve , shower pressure is now pretty poor , is it possible to put any type of pump on this configuration , maybe a single impeler pump on the hot to boost it still with the pressure equalising valve ??? if so would the pump go before or after the equalsing valve ????
if you can do it (cant think why not )
the pump would go before the valve
egualising valve drops both supplies to the pressure of the lowest feed ;)
