Hello. I installed a salamander rsp75 2.2bar shower pump to my last house. It is a conventional gravity feed system. HWC & bathroom on first floor. Cold tank in the loft. Pump only feeding the shower/bath. Rather than take the house to pieces I just put the pump under the bath on the original bath plumbing - ie not a dedicated feed. All worked great except the pump used to sometimes quickly switch on and off when I wasn't using it, sometimes repeatedly and normally when I turned on the basin tap (basin not connected to the pump). I assume it was caused by a pressure change triggering the flow switch in the pump. About to do a new install in my new house and want to make sure I dont have same problem. What do I need to do differently.
Thanks in advance.
Thanks in advance.
