Hi
I Have a stuart turner shower pump and it has started to momentarily switch on when a hot tap is turned off either in bathroom or downstairs in kitchen. If the tap in the case of a basin mixer is put in the cold water position first before turning off it does not switch on, if the hot tap is left running for a little while it does not do this either only when it is turned off relatively quickly. It is puzzling me what is causing this to happen. Can anyone advise what may be causing this?
Regards
Cono
Regards
Cono
