- Joined
- 27 Sep 2004
- Messages
- 1,301
- Reaction score
- 83
- Country
I have a shower pump to supply my shower.
I have problems with air getting into the system and can't figure out why, perhaps someone can see what is wrong!
The pump has it's own dedicated cold feed in 22mm from cold tank directly above it in loft. This reduces to 15mm at the pump.
Hot comes off top of tank with a Warwick flange, and down to pump. The only slight thing I have just realised is there is a small rise on the flexi pipe to the pump inlet?
The hot water is heated by immersion heater and by wood burner which gravity circulates via indirect coil. The air problem is worse if there has been a good fire lit that night and so the tank has got nice and hot. Note, it doesn't boil or anything, once up to 65C it kicks a pump in to circulate to some rads.
I think the air is in the hot but can't be sure. Shower is thermostatic one from wickes. If you turn shower off and then on again straight awAy you get a load of gurgling as air is coming out. A few times doing this will sometimes cure it. Other times it won't clear.
Any ideas how I can stop it!
