Shower pump
Only good manufacturer I know that makes them are Hansgrohe - They're Raindance panels are pretty good. That being said I'm not sure if they still do them .. need to check, not cheap though.
Have spent ages on the web and not seen any by that make. The other problem I have is most of them dont have swivel head and the ones that dont stick out quite far. Issue is it's opposite the door so need one that angles down and doesnt protrude too much. Have shortlisted this one. Can't see if it angles but it doesnt stick out too far trade off of putting on the handheld function then switch once in with door closed. https://www.bigbathroomshop.co.uk/m...r-head-hand-shower-and-body-jets-chrome-21246
Also very long overall. Good reviews but cant always trust those.
So my new tower has been delivered and thought I’d check where the bracket is to go and the flexi’s. I turned off what I assume is the cold feed which goes into the pump and the hot into pump from Emersion.But the water kept flowing. I’d turned the tap off as tight as possible. Ani ideas? You can see from pic the 2 white plastic pipes going to shower from pump and the 2 stopcocks. Also turned off the 2 valves to the second shower.
Any ideas on turning the water off? I turned the 2 off which go into the pump but water is still coming out normally. There are 2 pipes into the emersion, 1 into bottom has a stopcock but one into top doesnt
