I'm having problems with extractor fans in my shower room - not a shower cubicle, the room is about 1.5m x 2.5m. The fan ducting is rigid plastic through an 11" wall just below ceiling height. The fan is switched by a ceiling pull-cord the other side of the room. Over 9 years I've got through 5 fans. The first two were Vortice 5" fans with shutter and run-on timer. They lasted about 2 years each. The electronics for the run-on device seemed to burn out, so the third fan was the same type without timer. That lasted three or four years. I replaced that with a Vent-Axia 100mm fan with shutter and timer which lasted just over a year. Then came a Vent-Axia 100mm fan with timer but without shutter. It's an attractive, quiet, unobtrusive fan but it's lasted less than 6 months.
Is this normal lifespan for fans or am I just unlucky? Can anybody recommend an extractor fan that lasts??
