    Dismiss Notice
Shower tray up to plasterboard
Discussion in 'Plumbing and Central Heating' started by XanderHarris, 11 Jul 2021.
  1. XanderHarris
    XanderHarris
    4 Mar 2013
    155
    Thanks Received:
    Bradford
    Country:
    If fitting a shower tray on legs. Up to plasterboarded walls. One dot and dab, the other a stud wall. Would you usually fit the tray flush to the plasterboard or cut the plasterboard where the tray sits so sits in the wall. It's going to get panelled with 10mm panels after. Thanks.
  2. Sponsored Links
  3. Swwils
    Swwils
    2 Jul 2020
    548
    Thanks Received:
    101
    Country:
  4. denso13
    denso13
    22 Jan 2007
    5,143
    Thanks Received:
    1,074
    Country:
    Does the tray have upstands? If not I'd fit the tray to the plasterboard then fit the 10mm boards on top of the tray.
    • Like Like x 1
  5. XanderHarris
    XanderHarris
    4 Mar 2013
    155
    Thanks Received:
    Bradford
    Country:
    Thanks no upstand no. So just silicone the tray to the plasterboard. Then fit the paneling directly to the tray then silicone afterwards?
  6. Madrab
    Madrab
    4 Oct 2012
    8,031
    Thanks Received:
    2,270
    East Renfrewshire
    Country:
    Yup, +1 .... if you sink it in under the board then you may have a tight squeeze fitting the enclosure, that and the board gives you something to seal up against.
    As I always suggest, if it's plasterboard walls then tank the space, if you don't you may live to regret it.
  7. Sponsored Links
  8. XanderHarris
    XanderHarris
    4 Mar 2013
    155
    Thanks Received:
    Bradford
    Country:
    It's moisture resistant board I wasn't looking at tanking but would a pva mix be ok to seal the boards? Conserned water could get behind and draw the paper front off the boards?
  9. flameport
    flameport
    10 Mar 2007
    9,731
    Thanks Received:
    1,931
    Poole, Dorset
    Country:
    No, totally useless.
  10. Madrab
    Madrab
    4 Oct 2012
    8,031
    Thanks Received:
    2,270
    East Renfrewshire
    Country:
    PVA is water based, any condensation/water gets behind then anything attached to it will fall off.
    PVA is sometimes used as a sizing agent on plasterboard prior to plastering to stop the plaster drying out too quickly but even then it's not ideal.
    You need to waterproof the plasterboard and that needs a tanking medium to do it properly. It's not a huge job in the grand scheme of things.
  11. JP_
    JP_
    17 May 2012
    7,415
    Thanks Received:
    426
    Country:
    I'd tank it, and not use plasterboard, just to be safe.
Loading...
Share This Page
