Hello,
I am new to the forum and I like doing DIY around the house. Recently I have been looking at my shower..About two years ago we redone the upstairs bathroom and moved the shower from the place it was originally, it is now about 3m from the nearest foul pipe.
The spigot was as well removed and an air admittance valve installed instead.
The plumber did run a 40mm pipe between the beams but could only give limited tilt.
The shower was always smelly and slow draining so I opened up to have a look.
I changed the waste with a McAlpine grille 70mm high high flow waste and reconnected to the original flexipipe 40mm, I also made sure that the pipe was going down all the way (before it was going down, then up, then down again.
Now the draining is MUCH faster but I get an air lock.
Whever i start a shower the water pools up until i raise slightly the grille and lot of bubbles come out. Then it drains wonderfully.
Is there anything I can do to make it "do this on his own" i mean it is very annoying that the shower doesn't properly drain until the grille is raised to allow the air to escape.
Any suggestion?
Many thanks
Any suggestion?
Many thanks
