shower waste
24 Oct 2008
Berkshire
Hi Guys,
trying to fit a shower but the soil pipe runs across the back of the room approx 8" off the floor, do i need to get a pump wired to the shower to pump the waste up into the soil pipe or do i have to get the shower tray higher than the pipe?
Thanks in advance
either is acceptable depending on what you want, or who will use it or height restrictions if you need to build up shower, i have used a few archimedes pumps and they are great, 15mm connections in and out with a filter (which does require regular cleaning)
Which pipe runs across the wall 8" above the shower trap?
Cant you take it seperately out the wall and into the vertical stack?
the waste comes down into the room then runs across the back is doesnt go any lower than 8" untill it leaves the room,
