Morning!! I fitted a shower last night. But I couldn't completely stop a 'weaping' from the water connection: As you know, the short pipe connection from the shower is plastic. That went into a stainless compression fitting using a brass (maybe copper) olive, and stainless nut. I wraped a few lengths of PTFE around the screw thread that the nut tightens on to. I turned the nut a few times and turned the water on. It was leaking, so I gradually tightened the nut until it stopped, but the nut is quite tight now and the joint is still weeping slowly.
What is the best way to disasseble and start again?
How can I make sure it seals next time?
Thank you!!!!!
Thank you!!!!!
