I have had a Showerforce 8.5kw electric shower installed without problem for the last four years. However, recently the water flow began cutting completely after a few seconds and so is now impossible to use.
Before I spend a couple of weeks wages on calling a plumber, is there anything I can feasibly do myself ie, check for loose connections, change a fuse etc.
I have already tried replacing the external isolator pull switch box - but this has not eliminated the problem.
Power IS coming through to the shower unit itself, but for some reason no water is.
Thank you for your assistance
