I'm looking to fit a siamp skipper Flush valve but am wondering how the small float works that's attached to the side of the unit. Doesn't help that all the instructions provided are in French/German and Siamps UK website just has the basics, not the detailed instructions.
It says to install the float so as it's 2cm under water level, however my water level is set quite high to give a good flush so even with the float at its highest setting it is a lot more than 2cm under water level.
I believe the small float is to regulate the short flush of the flush valve but how does it work? Surely it's the fill valve that dictates things, not the flush valve.
