Nobody ever complains loudly, that their CWI works brilliantly, people only complain when it goes wrong. I had it installed in the mid 90's, it works, and no problems. It certainly helps keep the expensive warmth, where it belongs, in the house, and the cold out - things is, you need to do your part, in not generating excess moisture in inside the home.
Mine is fine. I live in a coastal area subject to winter storms and driving rain, exposed on the West. I get no damp. The heating costs dropped noticeably, and my old (15kW boiler) was no longer incapable of keeping the house warm on frosty nights. (Calculated whole-house heat loss at 20C difference dropped to 12kW)
Mine is a modern house with good quality brickwork.
-Get yourself a towel rail that hangs off the front of the radiator
-Put the towel on it NOT over the radiator
-If you can, leave the radiator on for a bit when the towel goes on
-Open the window for half an hour each morning
For many years we were nominated contractors to a large housing association.
Terrace housing full refurbishment back to floor joints & roof timbers.
All radiators were installed on outside walls and behind every radiator a 9x6 air brick .Where the tenants couldn't get at them!
With a reasonable level of warmth in the building, proper insulation, a reasonable level of ventilation in the correct locations, and the generation of moisture properly controlled - internal damp, and mould, is never a problem.
