The mould is not reappearing after mould removal.
Or to put it another way, the wall is not mouldy now you are no longer hanging wet washing against it and making it damp.
I'll never install this. Seen to many horror stories.
All radiators were installed on outside walls and behind every radiator a 9x6 air brick .Where the tenants couldn't get at them!
1. Mould was present when the rad was on the wall. As many posters have mentioned the likely cause is living habits/ draping towels on rad.
2. I specifically removed the rad to clean the mould and decorate the wall. The mould is not reappearing after mould removal. I have checked moisture levels and the temperature of the entire wall.
I've attached a pic immediately after removing the rad. Thick mould present on wall.
I'll never install [cavity wall insulation]. Seen to many horror stories.
But we should (collectively) know where it is OK to use and where it should be avoided. Tell us more about your situation and someone will advise.
