Hello again all...
I came on here intending to post the 3-way valve question below, but got sidetracked into reading this thread about how the A side of the valve is supposed to go to the radiators and the B side is supposed to go to the cylinder.
I checked mine and it's the other way round. And that might explain why the room thermostat can turn the heating on in the middle of the day when the controller is on 'H twice, W once', as well as the chronic 'lukewarm hot water' problem.
Before I get someone in to replace it for me, can I ask please, is it really that simple? could there be any sensible reason for installing the valve the other way round?
(This was the original question btw)
I'm trying to work out whether my 3-way valve is stuck in the 'both A and B' position.
Both output pipes are hot, but I wondered if that could just be because the heat is being conducted along the pipe from the open side to the closed side?
If I had any spare copper pipe I'd get the kettle and experiment. As I haven't, could I draw on your pipe heat conduction experience please?
