Of course it couldn't have happened in the summer...
No hot water, traced to no hot going into the cylinder heat exchanger.
I suspected that it is being caused a faulty / seized 3-port valve so popped the actuator off and tried to move the spindle by hand which it didn't.
So I tried again with a pair of pliers which was a mistake as even though I wasn't particularly rough, the spindle simply split and the top came off.
The actuator seems to still be working fine (selecting hot water on/off causes it to move approximately 30 degrees).
I have found a replacement body online https://www.heatingcontrolsonline.co.uk/siemens-22mm-3-port-valve-body-only-p-336.html.
Is it necessary to remove the whole valve, or can I just take the 4 bolts on the top out and replace the spindle? Is it necessary to drain the system down?
