Siemens oven, looks burnt at the back
9 Apr 2008
Sussex
As per title (image below)
My heater element recently gave up so I have replaced it (not yet tested the oven though).
After I swapped the element I turned the oven on and nothing worked apart from the LCD display - I noticed some burning to the insulation at the back. I later tried again and re-adjusted the clock - straight away the oven switched on (not sure if it heats yet though!), however, I am sure there is now more burning to the back, see image below (maybe as the power was switched on it over loaded the oven with power?!). I am worried something isn't quite right and have since turned off the power supply to the oven. Does this look normal or shall I call out an expert? Cheers!
