    Dismiss Notice
SIEMENS RWB9
Discussion in 'Plumbing and Central Heating' started by thekilljoy, 1 Jun 2020.
  1. thekilljoy
    thekilljoy
    6 Jun 2009
    10
    Thanks Received:
    Country:
    My central heating has developed a problem in that when I apply mains power to the system but with both the HW and CH switched off (lights out) the boiler fires up and activates the pump and central heating. I cannot switch off the heating.
  2. Sponsored Links
  3. muggles
    muggles
    28 Oct 2005
    12,959
    Thanks Received:
    2,916
    Daventry
    Country:
    Zone valve microswitch stuck on
  4. thekilljoy
    thekilljoy
    6 Jun 2009
    10
    Thanks Received:
    Country:
    But why does it trigger the boiler ignition when both CH and HW demands are switched off?
  5. CBW
    CBW
    26 Sep 2019
    7,200
    Thanks Received:
    1,894
    North
    Country:
    It has a permanent live and a switched live, so basically the switch is stuck in the on position, leaving it connected, whereas your programmer would normally remove the switched power from the zone valve, the output side of the valve is receiving power because the switch is stuck open.
    • Thanks Thanks x 1
  6. muggles
    muggles
    28 Oct 2005
    12,959
    Thanks Received:
    2,916
    Daventry
    Country:
    Because that's how they work. Programmer activates zone valve motor, which opens the valve and presses a microswitch. The microswitch contact sends power to the boiler, which fires up. If it's stuck open, it'll power the boiler at all times because the microswitch is continuing to send power to the boiler even with the programmer off
    • Like Like x 1
  7. thekilljoy
    thekilljoy
    6 Jun 2009
    10
    Thanks Received:
    Country:
    Makes sense, I assumed that the controller just caused valve to move. So is it just a case of having the microswitch replaced without touching the actual mechanical valve itself.?
  8. Sponsored Links
  9. CBW
    CBW
    26 Sep 2019
    7,200
    Thanks Received:
    1,894
    North
    Country:
    Usually depends on zone valve, and whether you can solder the microswitch, probably better just obtaining a valve head.
  10. thekilljoy
    thekilljoy
    6 Jun 2009
    10
    Thanks Received:
    Country:
    Having checked the valve.
    The CH valve it is open and the lever is floppy irrespective of whether or not there is power applied to the system. Does this mean it is just motor, needless to say it is in an incredibly awkward position and I hope it is not necessary to change the whole head.
  11. ianmcd
    ianmcd
    15 Aug 2010
    21,916
    Thanks Received:
    8,620
    Lanarkshire
    Country:
    yep the motor will have seized
    • Like Like x 1
  12. thekilljoy
    thekilljoy
    6 Jun 2009
    10
    Thanks Received:
    Country:
    As I said it is in an awkward place so although the motor replacement looks straight forward I will probably get someone to do it who has done it before and has double jointed fingers.
  13. ianmcd
    ianmcd
    15 Aug 2010
    21,916
    Thanks Received:
    8,620
    Lanarkshire
    Country:
    post a pic of where it is located
  14. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
