Hi
The dishwasher is just over 2 years old. Last night after it had been started, I became aware of a loud continuous buzzing sound from it. The machine was still full of water when I checked. The check water light was lit.
This morning I emptied the machine, checked the waste hose which was clear and then removed the filters and checked the inner compartment of the pump. I couldn't see, any thing jamming the pump. At first it felt like something was as I couldn't turn it all However it then did turn. I switched it back on and the check water light had extinguished.
I set the machine off and it started at first but then started making a buzzing sound part way through the cycle. It went through the cycle and then started making the buzzing sound again. On checking at the end of the cycle - the end programme light was illuminated but the machine was still full of water. I touched the float head in the bottom and the buzzing started immediately.
Is it the pump that has failed - if so how do I get at it?
