Silly Question
1 Apr 2010
Looking at Rehau windows, when they talk about their 60mm or 70mm windows, what dimension are they referring too?
The thickness, Inside to outside
I'm looking at some online sites, if you had a choice between
Rehau Tritec (60mm i think)
Rehau 706 (70mm)
Duraflex
Why would i choose 60mm over 70mm, is it just to match existing? Are the Duraflex any good? Duraflex seem most expensive, but only by a little, so wondering what if any benefits they offer
I also saw on another site, it says for the rehau windows "Available in Slimline 52mm, medium 62mm or 75mm outer frame", i'm guessing this refers to the profile width? Is this again just to match existing, as i can't imagine many people choosing chunkier plastic? Cheers
Rehau S706 all day long if duraflex is the other choice
Also a 70mm window will be designed to take a 28mm dgu, the 60 might only allow room for a 24mm, still meets regs mind but a 28mm is by far better, you would also need to question the u value of a 60mm profile too, might not have enough chambers to reach a high enough value?
Depending on the supplier, both the 60 and 70mm should come with 28mm units.
The slim outer frame enables you to improve the energy performance of the window.... Less frame/more glass = better efficiency
There are other ways to reach a,b or c rating ie frame thickness, glass and reinforcement type. Explaining energy ratings to customers isn't easy
http://www.astrasealdownloads.com/files/EnergyRatedBrochure.pdf
Performance wise they're near enough the same, looks wise I'd go for TRITEC, overall the 70mm wins, just feels stronger, especially the doors compared to the 60mm
Is it only the 60mm that is Tritec, or can you get both 60 and 70 as Tritec? I looked on Rehau website, and the 70mm appears to be called TOTAL...?
60mm is the tritec
70mm is s706
Total 70 is also 70mm but has more chambers within the profile, this improves the energy rating, as I said before it can be complicated :eek:
