Hi there - i have a couple of questions if i may which i'd appreciate some advice on:
firstly we have a SIME boiler (400 i think). The water only seems to get hot when the central heating is switched on. If we run the water whilst the heating is not on then it gets lukewarm at best. Any ideas??? (also how much might a new bolier cost - ballpark as i'm told these boilers aren't the best).
Secondly we have a noisy radiator - basically when the heating comes on it clunks at about 2-3 second intervals for periods of about 1minute. It will then stop for a few minutes and then start again. I've seen the suggestions about securing the pipes but i would have only thought this happens as the pipes are warming up not once they are already warm?
Finally, another radiator in the house makes very loud noises at the thermostat sometimes. A minor twist of the thermostat and it goes away (until next time). Basically we have to leave the thermo fully open or the problem reoccurs. I've been told that its on the exit and not the entry pipe - is likely to be the problem?
Thanks in advance for your suggestions.
