simple problem- difficult solution?
1 Oct 2006
I am fitting a basin in the en suite, and the existing plumbing only has a cold water feed. As it will only be for hand washing after the toilet, I have decided to live with this, rather than rip up all my floors to get a hot water pipe to it.
The basin I have has 2 tap holes, so I want both to have (cold) water, rather than 1 not working. I will be running 15mm flexible plastic pipe behind plasterboard that will be tiled. I went to B & Q today for the bits, and was surprised to find they didn't sell a "Y" shaped adapter, as this seemed to be the simplest method of dividing the water from a single pipe to 2 taps. The best I could find was a "T" adapter that would then have needed extra elbow joints and seemed over complicated for the job.
Do the "Y" shaped adaptors I envisioned exist?
Do I need to fit a T then 2 elbows to each pipe to get the pipe split?
Cheers
Andy
Why not just use a standard chrome or white or gold blanking disc in the spare tap hole? :idea:
67 pence.
Sorry, I can't have explained myself very well.
I want 1 pipe to feed 2 taps, not 2 pipes to feed 1 tap (which I think is what you were thinking).
Andy.
T directly under one tap then only one elbow needed.
This takes me back to the Crypton Factor.
He know's what you said. He was just suggesting the option of having just one cold tap (why have two?). If you must have two, then you need a tee, simple as that. It's you're choice.
