Single flow shower problem.
5 Oct 2008
Devon
I recently changed a rubber flange (washer) inside the shower tap (Bristan) and since I put it back together it wont work properly, ie the water is the same temperature (coldish) whether I want it hot or cold. The hot water pipe feeding the tap is hot though. Can anyone help?
What type of services are supplying this valve?
For example, pumped, tank fed, mains fed, one of each..... ?
....I meant it was ok temperature wise...I took it apart because it was dripping, and we all know how annoying dripping taps are!
Could you possibly risk prosecution under the wearily Draconian provisions of the Data Protection Act, and disclose the model details of this shower valve?
