Single glazed glass in wooden frame
13 Nov 2008
Avon
My kitchen has a conservatory attached. Between the two the window in the kitchen was removed years ago but now I wish to put something back. The opening is say 5ft x 3 1/2ft but the window will only be about 1meter square & the other part will be a few shelves.
I’ve made a 3 x 2 frame then added to it some batten. My plan is to measure the opening then minus say 6mm from the measurements. I will then have some 4mm glass ordered.
Now should I lightly paint this wood before the glass is fitted or after ?
Once the glass is here I plan to use a small amount a clear silicone around the inside edge on the batten. Two screws in the bottom piece to keep it up off the 3 x 2 wood. Place the wood into the frame & sitting up in the two screws & two battens then either side just to allow the silicone to set for a day.
Next day remove these two battens & replace with the finished wood, also includes removing the two screws.This then will have a small gap around the glass from heat expansion etc.
Run a small amount of the clear silicone around where glass meets the batten wood.
FYI this window is about 10ft from conservatory windows should you need to know.
The kitchen / conservatory goes to rear garden & sun is at front of property so sun heat isn’t directly on the glass.
Does this sound correct.
Thanks.
Paint the wood before glass is fitted to seal and it will look white.
If you don't it looks bad. Same for internal glass panel doors. I've seen some not painted and the dark wood can be seen as a contrast to the white
DG was to expensive & property up for sale.
Im now painnting the frame
