Hi - I had a new brick shed built in my garden two winters ago, and my mistake was keeping it as a single skin brick wall for the sides and rear. All internal walls have been skimed and painted but I'm now getting damp especially where I have shelving against the walls where air can't circulate.
What options do I have to stop the mould? If I line the walls with batten frame and fill voids with insulation, will that cure the problem? The shed is fairly small, so I cannot afford to go deep with the insulation. I don't mind the top layer being 12/18mm ply (instead of plaster board) as I can also screw things directly into that too.
Thanks very much
Thanks very much
