Sink popup waste rod
20 Jun 2007
Hi all,
Having a small problem (diy) fitting a second hand sink waste popup.
Does the push rod just sit in the recess at the end of the push lever? Or does it fit in a little more securely some how?
Thanks!
It should screw in (if I am understanding your question correctly)
Yeah. The top bit of the rod in your image. Connects to the level on the tap. Seems to be no thread on either end, and it won't push in. I have jammed a bit of plumbers gold in it. Might gaffer tape it as well when it has set. See how that fix works out for us :/
