Sitting sockets
19 May 2007
What are the regulations about sitting sockets in a new kitchen?
Can you still have sockets near the skirting or do they have to be a certain height?
How about near to windows or internal corners?
How about from water, is it a metre from the sink or a metre from the tap?
As far as sockets adjacent to sinks (and hobs, for that matter), building regs advise 300mm minimum, with the NIC preferring a metre where possible.
As for socket heights, 7671 does not stipulate. But what they do say is that the siting of electrical accessories should be such that they would not be subject to damage, or such words.
If you are doing a refurbishment or new build, Part M comes into play. But if not, a little above the skirting is fine. I like a bare minimum of 6" to the bottom of the socket & recessed - nothing like a surface socket to attract missiles...
Our existing sink has a double socket in the cuboard below it. Easily within reach. Not good me thinks. At least the new kitchen will have the sockets out of reach of the sink. Exactly the same level, flush and plenty of them. Borrowed a laser level that spins around and made sure they are the same level all the way around the kitchen. Yes yes, I know a bit anal but attention to detail is everything in a new kitchen. :D
If you are doing your own work the regulations about siting sockets (or any electrical work in a kitchen) include that you must notify the local authority before you start work and pay the appropriate fee.
Your alternative is to use a competent, registered electrician.
I'm just running the wires and sitting and installing the back boxes etc Its a new kitchen extension and building control know all about it. Sparky is back from his ladyboy exploits in the far east soon and will connect up everything. Thats assuming he hasn't caught anything! :-)
