Combi or system gas boiler? Just bought a large victorian detached repossession and hope to dabble in B&B business. It has an aging gas boiler and two fairly large hot water cylinders, but they have removed 8 of the radiators before being evicted. With peak demand issues in the morning planning on 6 en-suites with electric showers and just one bath. While a previous experience with a combi in a small semi 15 years ago took an age to run a bath, I am not sure if they are any better now. However, with mostly showers it seems inefficient to have large amounts of pre-heated stored hot water. Leaning towards a larger Combi boiler or two, but will this be sufficient?
Insulation? Also, with four external solid walls, EPC is suggesting some really horrid heating costs: £8000+ a year! This is probably so bad because no C/H and most Rads removed at present, but apparently previous occupants gas bills were over £4k a year. Plan to maximize loft insulation, suspend insulation under the floor boards and knock through the base of a fire place in the middle of the building to open both sides (with RSJ) and have a multi-fuel stove to blast out heat in all directions in the evenings for peak times. However, I cannot insulate the exterior walls and the interior has some very ornate coving so would be a problem to put the recommended 60mm internal boards up. Can get away with a 1 inch board, or would this be little use? Also need to consider rads and heavy items would need longer screws to hang, and there would need to be susufficeientable behind the electrics to bring the facias forward an inch or so. Cannot find any advice on internal insulation on solid walls.
Stained Glass Sash Windows? Finally, the sash windows on three of the walls have stained glass at the top. While it is not listed it would seem criminal to replace these, but they are very poor for thermal and noise insulation and are rotting in places. Could the stained glass be incorporated into replacement wooden double glazed sashes at a reasonable cost? Alternatively, any ideas on sliding secondary units?
Suggestions, other than should have bought a modern house, appreciated.
