The loads you have quoted are quite small in total. However, despite the best intentions of the owner, extension cables rarely power only the planned loads throughout their life. Therefore, I suggest you obtain some 2.5mm flex, protected by a 13A plug. You can then use the extension cable for virtually any domestic device, or devices, up to a total of 3kW. Incidentally, I doubt that your devices will exceed 1 kW. You need to examine the data labels on the back of the devices and add up the ratings.
You will only probably need a lead rated a few amps for what you need, what size fuse is in the telly plug? Is there a wattage on the label of the telly? How long lead do you need?
Thanks for your response. The wattages are as follows:television 55, dvd recorder 30 and video recorder 16 (Total 101). Does that help, bearing in mind I want the thinnest possible cable?
if you're putting it in trunking, why won't you use 2.5mm T&E? it's cheap and widely available and will easily cope with more than 13A. You could run it as a spur if you want, or via an FCU and put a multi-way on it.
If your familily don't understand that fuses need to be sized to match the cable and that thin extention leads are not suitable for vacum cleaners you need to educate them on this fact.
