Hi.
Quoting for work in conservatory. At present, the meb on a quote is 6mm.
Now if i calculate the required csa of the main earthing conductor using S= square root of (I squared x t) all divided by K
I have I= mpefc=230/0.56(ze) =410A
t = 10 seconds for an 80A BS1361@ 410 A
K = 143
Required S therefore = 10mm
So, using 544.1.1 The 6mm meb will be ok, won't it?
or should i calculate using the max efli that could occur of .8,
which comes out at 16mm, and therefore 10mm meb is needed.
K = 143
